Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Drivers Side window stopped working!
Old Apr 2, 2009 | 12:23 PM
Viper99's Avatar
Viper99
Angry Drivers Side window stopped working!
Hello-
To anyone who can help.. I have an 03 Mach 1 and my drivers side window has stopped working. Any time that i hit the switch for the window i hear a clicking sound that comes from around the fuse panel box under the dash. I have replaced both the buss fuse in the fuse box and the actual switch. What could it be? Thanks for the help
Ryan Lockwood
Old Apr 2, 2009 | 10:52 PM
Pohatu18's Avatar
Pohatu18
Does the passenger side work? I took my door apart to change my speakers once and I forgot to hook a wire harness in that connects near the rear bottom that I guess does something with the motor. if not your motor may have gone out
Old Apr 3, 2009 | 05:02 AM
FELEN's Avatar
FELEN
same thing happened to mine has your car been sitting out in the sun?? my friend with a 03 cobra had the same problem the way he got his to work was hold down the button to put the window down and slam the door..... tried it on mine but didnt work i think my motor is out for good so im gonna take the door panel off soon and check it out..... i hate going to drive throughs =\
Old Apr 3, 2009 | 10:21 AM
Viper99's Avatar
Viper99
The passengers side works perfect. what would the clicking be??? just the motor going out?
Old Apr 3, 2009 | 03:16 PM
StockD15b's Avatar
StockD15b
beat on the bottom of the door a couple times near the bottom as you work the button. that dosent work directly hook a power source up to the motor. if that dont work. you'll need a new one. should be 3 nuts that hold it to the regulator
Old Apr 3, 2009 | 03:24 PM
jwog666's Avatar
jwog666
the clicking noise is the one touch down relay. pull the door panel and unplug the motor. check for power and ground at the motor with a test light while operating the switch in both directons. if thats ok you need a motor.
Old Apr 3, 2009 | 04:04 PM
zanypunk's Avatar
zanypunk
It's the motor. Sometimes that happens to 06 stang, specially during the winter time. I tried everything from fuse, you name it and it's always the motor.
Bullet 67
Sep 18, 2015 08:00 AM
waid302
Sep 14, 2015 11:19 AM
kirk35
Aug 17, 2015 08:42 PM
philster0306
Aug 10, 2015 11:33 AM
