Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
***DM1's Eaton swap build*** all eaton stuff in here
Old 12-15-2010, 03:54 PM
  #121
darkmach1
darkmach1's Avatar
Originally Posted by blackGTcp
Alrite cool just wanted to make sure i ordered the right part. Do you know if the shop ran a relay for the i/c pump or if they just wired it into the engine harness?
How much was the cobra power steering line? Its just one right?
I'd really like to do the job the right way and get that hose
Wired straight to harness and IMO its the best way to have setup, this way the car does not need to be on in order for the pump to run. Its only one PS line, part number 3R3Z-3A713-AA and costs about $60, you can get it from LooknGo, he's a member on M1R.
darkmach1 is offline
Old 12-16-2010, 02:21 AM
  #122
blackGTcp
blackGTcp's Avatar
Thanks for the help. For some reason i thought that hose would be like $300. Everyone seems to swear by how much they are. Ill deffinatly order one of those. I think the only thing my install is waiting on now is one coolant hose and cobra pumps/tank. Like I said, I want to do it the right way from the beginning. Hopefully ill join the eaton club soon
blackGTcp is offline
Old 12-16-2010, 03:37 PM
  #123
darkmach1
darkmach1's Avatar
Cool, and if I might add, Im sure you'll want more power after about 3-4 months so instead of changing the pulley later on and retune, try to get your hands on a stage 1 steggy ported eaton and be done with it until you build the motor. More flow>more boost.
Old 12-22-2010, 08:15 PM
  #124
blackGTcp
blackGTcp's Avatar
Did you do an EGR delete? Just wondering because I dont see the wrap around bracket on the SC or all the vacs
Old 12-24-2010, 09:00 AM
  #125
darkmach1
darkmach1's Avatar
Yes I have an EGR delete, not only does it keep the engine bay cleaner but also the internals.
Old 04-17-2011, 12:51 PM
  #126
Explosive
Moderator
Explosive's Avatar
You can expect a PM from me in the near future. I'm acquiring parts for the swap on my 03 and have a few questions.
Explosive is offline
Old 04-17-2011, 12:53 PM
  #127
darkmach1
darkmach1's Avatar
You got it.
Old 09-07-2011, 05:24 PM
  #128
Explosive
Moderator
Explosive's Avatar
Fall is coming. Hope to do my swap over the winter !
Old 09-08-2011, 06:22 AM
  #129
302army187
302army187's Avatar
you wont do it...........
302army187 is offline
Old 09-09-2011, 08:48 AM
  #130
darkmach1
darkmach1's Avatar
Best of luck..
Oooof!!! Nasty callout.
Quick Reply: ***DM1's Eaton swap build*** all eaton stuff in here
