Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Cobra Cams?
Old Jan 6, 2010 | 04:09 PM
jmac72187's Avatar
jmac72187
corner carver
Default Cobra Cams?
So I am pulling my extra longblock apart in a few weekends. I am not sure what I will do with it but I am considering throwing some cobra cams in there.
Which cams do I use? Intake? Exhaust?
Anything else I should look into while it is apart?
Old Jan 6, 2010 | 04:36 PM
mrtstang's Avatar
mrtstang
I didn't know that the Cobra cams were more aggressive than Mach 1 cams.
Old Jan 6, 2010 | 07:18 PM
Shaken's Avatar
Shaken
Here Rod,
http://www.mach1registry.org/forums/...71&postcount=2
There is a better break down on the specs on this site somewhere but this shows the life and duration at 50. From his posts he states that you need to advance these cams to get back the torque.
Old Jan 6, 2010 | 07:37 PM
darkmach1's Avatar
darkmach1
The best stock cam for a Mach is the 98 cobra intake cams, the 99-01 are good but not as aggressive as the 98. The 03-04 cobra cams are exactly the same as the mach1.
Old Jan 6, 2010 | 07:39 PM
jmac72187's Avatar
jmac72187
corner carver
Thanks for the info guys.
How much do the intake cams run normally?
Old Jan 6, 2010 | 07:41 PM
darkmach1's Avatar
darkmach1
you can find 98 intake cams for about $200.
Old Jan 6, 2010 | 07:42 PM
jmac72187's Avatar
jmac72187
corner carver
That isn't too bad. I will probably throw them in while I am in there anyway. Some cheap power.
Old Jan 6, 2010 | 08:00 PM
darkmach1's Avatar
darkmach1
Like Shaken said, make sure someone knowledgeable does it because they have to be degreed correctly.
Old Jan 6, 2010 | 08:02 PM
jmac72187's Avatar
jmac72187
corner carver
Will do. I will be doing the tearing down but not the assembly.
The guy helping me has 8 second cars in his shop. He at least knows something.
Old Jan 6, 2010 | 10:36 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
ford gt cams ?
