Guys with superchargers, GTFIH!
#21
sounds like you have the bolt on area covered
some people will just throw a blower on..which is fine as long as you keep it safe. but if you plan on wanting more power its a good idea to do the motor first. this way less of a hassel (taking blower back off, reinstall etc..). i heard a good rule of thumb when having a blower or F/I is too put money aside little by little for the motor "just" in case lol.
id do a clutch before anything..you will roast that thing to pieces
furinox sounds like you got one helll of a deal on that blower
#22
I'm thinking either a full Eaton kit or a P-1SC and run low boost for maybe 400 rwhp for starters. Then once I build up the internals I'll up the boost.
#23
Would there be anything "wrong" or "pointless" if I were to maybe build up the engine (forged internals) first, to prepare for a blower in the future? Of course, assuming I could only do one or the other (building up the engine and getting a blower at the same time being NOT an option).
#24
Or hooking it. Traction is usually what breaks parts and burns up clutches. If you stay on street tires and don't power shift into gears like 4th and 5th that put strain on your clutch due to not being able to spin the tires, then you should be okay for awhile. Its still a good idea to upgrade your clutch though. Its not necessarily going to go up in smoke on you right off the bat, or just because you give it hell from time to time, but it is going to wear out twice as fast with an extra 100 rwhp. I would upgrade it and be done with it.
#25
#27
My stock clutch lasted 2 weeks after installing the blower. The 28 spline stuff is fine as long as you run street tires. I ran my stock rearend for a year after having the blower and never had a problem with it. I recently switched to a 03/04 cobra IRS though.
I went with 10cc pistons that lowered my compression to about a 9.1:1. If I did it again I'd put flat tops in it and stick with 10:1.
#28
With all this upgrading, is this, again, assuming I'll be racing? Would I have to worry about the clutch and bottom end when I daily drive it like your typical Camry driver?
Perhaps if I drive spirited or take it to the track often, but I would think I'd be good to go for a while since I don't really push the Mach very hard. With that being said, regardless of my driving style, I do plan on beefing up to a 31 spline.
I'm really leaning towards an Eaton kit though. Not only do I live near a guy on M1R that pieces these kits together for people (LOOKnGO), so that'll save on shipping cost, and then another buddy on M1R, and who also lives near me, would help me install it so that'll cut the cost of install/labor.
#29
