Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
PCV valve
Old Mar 2, 2010 | 12:00 PM
boduke0220's Avatar
boduke0220
Default PCV valve
So I've noticed Most Mach's have a tube going from the valve cover to the Intake tube, mine has a small K&N filter there instead, will this hurt anything? does anyone know where i can get another stock piece to go there, i dont really like the filter
Old Mar 2, 2010 | 01:07 PM
Mach1man's Avatar
Mach1man
Actually, your PCV valve is on the driver's side, and is routed directly to the intake manifold. The passenger side is basically a pressure vent, and crankcase vapors, and maybe some oil blowby, get re-routed back into the intake tract to get re-burned, instead of getting dumped into the atmosphere.
The setup you're describing is usually used by people with superchargers who don't want the oil blowby getting sucked up into their blowers! It won't hurt anything, it's just not politically/environmentally correct.
Old Mar 2, 2010 | 04:17 PM
Stone629's Avatar
Stone629
Over time, your intake and throttle body with get grimey from the intake tube, but it doesn't really hurt anything either way.
Old Mar 2, 2010 | 05:11 PM
Stevecooper's Avatar
Stevecooper
If you delete the PCV system the computer needs to know about it, otherwise you fuel mass calculations will be off. Do you know if the car's tune has been modified?
Old Mar 2, 2010 | 08:05 PM
boduke0220's Avatar
boduke0220
no, but i doubt it has. all the car has is a borla catback
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
