Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Oil and Oil Filter Questions, First time doing an oil change
Old Jul 5, 2010 | 04:13 PM
RickyD53's Avatar
RickyD53
Default Oil and Oil Filter Questions, First time doing an oil change
I've had my 04 Mach 1 for about a month now and wanted to change the oil but I wanted to do it myself. Im unsure of what type of oil to use and what type of oil filter to use. I want to use the best stuff for my car to make her last longer. any help is appreciated.
Old Jul 5, 2010 | 04:36 PM
DreamerGT's Avatar
DreamerGT
check the oil section you should find your answer there.
Old Jul 5, 2010 | 04:42 PM
invisableflames's Avatar
invisableflames
I prefer redline fluid and motocraft filters. as stated check the oil threads and you will find tons of information and opinions.
Old Jul 6, 2010 | 08:55 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Im confused as to why this is in the Mach 1 section...but i would use AMSOIL filters and oil
Old Jul 8, 2010 | 07:13 PM
mestit3's Avatar
mestit3
takes 6 qts of 5-20 of your brand of choice. I use motorcraft synthetic blend and a motorcraft filter. you'll need a 5/8" or 16mm socket.
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
algregory
Sep 6, 2015 05:52 PM
BCATL79
3.7L V6 Technical Discussions
Aug 13, 2015 07:41 PM
