Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Cooling, overheating problem? Help
Old Jun 3, 2012 | 10:46 PM
Rdzmach1's Avatar
Rdzmach1
Default Cooling, overheating problem? Help
So as I drive my 2003 mach1 my a/c stops blowing cold air.. And then my temputure guage starts to get hot.. Anyone have a clue on what kind of problem I'm dealing with or what I could do to fix it? Help please! Greatly appreciated!
Old Jun 5, 2012 | 12:38 AM
03tripleblack's Avatar
03tripleblack
Same thing happened to me last week when it was 96*. I had just replaced the thermostat a couple weeks prior, & thought all was fixed. I started limping home, & the temp came back down, to normal by the time I got home. I added some coolant to the overfill, & watching closely. Hasn't repeated, but makes me nervous. I detect a slight coolant odor too, but no leaks on the ground.
Old Jun 12, 2012 | 09:03 AM
Goldorak's Avatar
Goldorak
I also had the exact same problem last saturday. Did u guys found out what was wrong?
Old Jun 13, 2012 | 06:52 PM
03tripleblack
Nope. I check my coolant level evey time the car is cold, and have been adding a little every time to bring the level up to the "cold" line. The amount I add is getting less and less. I think the shop didn't fill mine up correctly when they did the t-stat. I read on Mach 1 registry the coolant refill is kinda complicated. I'm not finding coolant in the oil, so I don't think I have a head or block crack. I'm thinking my new t-stat got stuck for a few minutes. A/C has been working correctly since, and no overheating. Crossing fingers. May have it checked before we drive to Myrtle Beach for Mustang Week next month.
Old Jun 14, 2012 | 09:09 AM
Goldorak's Avatar
Goldorak
Mine haven't overheat since then, but a/c is not working... only hot air. I wonder what's wrong. I just bought the car a month ago, i have no place and no tools to fix/check it myself. I guess i'm gonna take it to the dealer. here in mexico most of the mechanic are bad or thieft!
Old Jun 20, 2012 | 12:52 PM
Gerry Hazuka's Avatar
Gerry Hazuka
my tempurature gage redlined Monday while traveling on the highway at 70mph. as soon as I got off the highway on to the back roads, it cooled down. The fluids are all full, and I believe the fan is working fine. Any ideas what happened?
Old Jul 9, 2012 | 06:29 PM
mestit3's Avatar
mestit3
On the 4V motors you have to add coolant to the plug on the crossover. What is in the overflow is no indication of the actual amount of coolant in the system.
http://reischeperformance.com/refill.html
Old Jul 9, 2012 | 06:32 PM
mestit3's Avatar
mestit3
03tripleblack, if you perform the procedure in the link above I'm almost certain you will find that it will still take a large amount of coolant even though it appears to be full.
Galactic
Apr 29, 2019 02:56 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
