November 1st, MILAN
#21
I'm in for the TNT at Milan - but now where can I refill my nitrous before then?
I stopped by my usual place (Lukovich Racing in Chesterfield) to fill my tank since it is nice and cool out today but they are out and don't plan to refill until the spring.
Does anyone know who in SE Michigan/Detroit (east) area still has nitrous available?
#22
Jim;
Just called Livernois. Sat. Hours: 9-1 Refill NOS for 3.50 lb. Ph # (313) 561-5500
Looks likes weather might change our plans. My backup plan is to go display Steeda
cars (Sam & I) at Sam, Bill's workplace indoors.
#23
#25
Ps I might turn up
#26
I just found out that a guy in Port Huron refills bottles, and has some available. So I should be all set - saves me a lot of driving to get the juice. Need to work on the blow down tube this Saturday, and if enough time I'll see if I can get the driveshaft loop on using my ramps - not sure if that will give me enough clearance to work though. I also want to pull the plugs and check them out, regap or replace if necessary after several nitrous passes this year.
I hope you can make it over Dale. I'm anxious to give Milan a try - hopefully I can hook up and get the 60' way down.
#28
