Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
mustang with a little lightning
Old 03-20-2014, 07:54 AM
Fglcountryboy
Fglcountryboy's Avatar
Exclamation mustang with a little lightning
Hey guys I am about to buy a 2000 mustang gt and I was wondering if a 351 Windsor in it with what kind of engine mounts and what 6 speed manual transmission goes behind that and would it be easier to make the 351 fuel injected or keep it carburated
Fglcountryboy is offline
Old 03-21-2014, 02:31 PM
PNYXPRESS
PNYXPRESS's Avatar
You can put any motor into any car as long as you have the know-how, tools, money, and time.
PNYXPRESS is offline
Old 03-21-2014, 10:46 PM
bluebeastsrt
bluebeastsrt's Avatar
351 will fit no problem. Carb will be ALOT cheaper than fuel injection and I'd go with a tremec. The torque from a 351 would probably give a stock T5 fits.
bluebeastsrt is offline
Old 03-22-2014, 07:48 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Don't know if you have inspection in Illinois but it won't pass it with a carb...
A T5 behind a 351 should last about a week.
pascal is offline
Old 03-22-2014, 07:55 AM
Fglcountryboy
Thank you guys. If I keep it carburated how do I get the gauges to work or do I buy different ones and what about all of the sensors what do I do about them
Old 03-22-2014, 07:59 AM
Fglcountryboy
What do you guys think about the T56 transmission
Old 03-22-2014, 01:15 PM
bluebeastsrt
I'm doing a carb swap this spring when I go to the dart motor. From everything I've read you can keep your gauges and use the portion of the engine harness that operates the gauges lights etc. As far as the sensors go your going to have to do a little research. But you'll need an old school ignition system. The pcm will be useless once a carb is installed. Google is your friend.
Old 03-22-2014, 04:36 PM
pascal
pascal's Avatar
Very good tranny.
pascal is offline
Old 03-23-2014, 07:48 AM
Fglcountryboy
Thank you again guys
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: mustang with a little lightning
