Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
408w Swap
Old Feb 16, 2016 | 09:39 PM
muscular3's Avatar
muscular3
Default 408w Swap
I have a 91 Mustang gt with the on3performance turbo kit, and a month ago blew the crankshaft in half and broke off a couple chunks of the block so im looking to swap to a 351 base motor. I found a local builder who sells a 408w shortblock for 3300$. Includes all the machinework on the block like bore and clearancing for the stroker. Heres the parts:
OHIO 4340 Forged 4.00" crankshaft(Internally Balanced)
SCAT 4340 6.200" H-Beam connecting rods w/ARP Hardware
WISECO Custom 2618 Forged Pistons, With Twisted Wedge Valve Reliefs and GFX Rings
Fel-Pro Rear Main Seal
ARP Main Studs
Clevite "H" Bearings
Durabond Camshaft Bearings
ARP2000 Rod Bolts
I know i will have to do some modifying to the headers to fit and work with the turbo kit, but im not concerned with that. My questions are what would be a good recommended camshaft? I want a nice thumpy sounding cam but not at the risk of losing performance. And do many people have problems with 351 blocks at around 700-800 Horsepower? Ive read all around people saying they can take a hell of a beating as long as you use good arp bolts. im looking to build a 700ish horsepower turbo motor. If anyone out there has a 408 turbo build feel free to add some input. As far as internals, i dont see any problems with the internals holding the power as they are relatively high quality parts.
Thanks for any help.
Old Feb 24, 2016 | 11:44 AM
jsimmonstx's Avatar
jsimmonstx
If you want your engine to live a long time with boost, start with something like a Dart block. You simply cannot discount the benefit of having 4-bolt mains. With a 4-inch stroke, you end up with 427 cid. Even with boost, there is no replacement for displacement.
As far as a rotating assembly goes, make it easy on yourself and get one from FordStrokers.com. Try not to go higher than 9.5:1 on your static compression ratio, otherwise, boosting the motor won't be as efficient money-wise (why spend all that money on a Turbo, only to be able to use no more than 5 pounds of boost?). To calculate your static compression, you need to know what heads (I recommend AFR 220's with your choice of combustion chamber size) and head gaskets (compressed thickness) you'll be using. There is an online calculator available that lets you play with numbers.
As far as ARP goes, yes, yes, and yes. Also use ARP head bolts. Heads up - using ARP fasteners get's expensive fast, but they are WELL worth the cost.
I built a 427 Windsor last year, and put in a TrickFlow stage 3 cam and am using 1.7 rockers. The choppy idle is *amazing*.
Are you planning on running gas or E85? Carb or fuel injection? Personally, I think a carb is the way to go, but hey, I'm freakin old...
Sandmanbjj
24
Jun 5, 2016 07:43 PM
nj07
Feb 18, 2016 02:36 AM
65mechanic
Dec 26, 2015 06:05 PM
Texas Stang 126510
3.7L V6 Technical Discussions
Dec 23, 2015 05:50 PM
teeeeg67
Dec 10, 2015 04:36 AM
