Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Danger with electronic cutouts after headers
Old Jan 4, 2021 | 12:35 AM
Amortiz's Avatar
Amortiz
Default Danger with electronic cutouts after headers
Hey I am in the process of swapping a 2016 5.0 into my 97 F-150. I am almost done with the build but I can't decide where to put my cutouts on my exhaust. I have long tube headers and two 3" electronic butterflyutterfly valve cutouts that I'm going to install so my truck can be silent at home but loud on a late night drive. I've been hearing conflicting opinions on the safety of putting cutouts right after the headers. The main thing is that cold air can rush back in and burn a valve on shutdown. However if I make sure I don't have them open on shutdown I should be fine right? If I don't put them after the headers then I'll put them after the cats, but that will take some more fabrication to fit. Have you guys done anything like this and if so how is it working out?
Thank you.
Old Jan 22, 2021 | 06:16 PM
David Young's Avatar
David Young
Not very many people have installed cutouts. Are you going to use a dual exhaust? With an X-mid pipe or H-mid pipe? If so, I've read you should install the cutouts 'after' the X or H mid pipe. You know, before the mufflers Just from what I have read
Old Jan 27, 2021 | 07:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
To avoid the potential for problems, at or after the crossover pipe is ideal. Before it, not only do you lose performance but, you have the potential to get the burnt exhaust valves or even a backfire from lack of scavangeing effect.
portstangly23
May 15, 2013 09:38 PM
stangrookie302
Apr 16, 2013 07:22 PM
dmaclaren
Aug 26, 2011 09:14 AM
Mach1
12
May 23, 2008 12:08 PM
northbaseball22
Nov 15, 2007 09:56 PM
