Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
starter
Old Jul 2, 2007 | 01:21 PM
my77stang's Avatar
my77stang
Default RE: starter
i dont believe anyone makes them, but i can bet you phil knows where to get one. theres also a place in PA and a place in VA that have II cars and parts......... im gonna gather a list up supply sources and make it a sticky for you guys
Old Jul 2, 2007 | 01:53 PM
gwb16's Avatar
gwb16
Default RE: starter
I haven't checked with Johnsons Mustangs in Chesapeake, VA. I've been looking on line, found one company in VT that will totally rebuild your old one, price ranges from 75 to 150 depending on the type and how extensive the repair will be....my guess is 78 M-II + really bad shape = $150! Good thing about him is he'll give you a 24 to 48 hour turn around.
SSC Enterprises carries the o-ring and the retainer ring, he just doesn't have any sending units right now.
Do you have Phil's number that you can post or e-mail to me? He's in AL right?
Old Jul 2, 2007 | 02:30 PM
my77stang's Avatar
my77stang
Default RE: starter
i believe it is 334-298-3038
Old Jul 2, 2007 | 04:14 PM
gwb16's Avatar
gwb16
Default RE: starter
yep that's it - did a Google and found it, actually you had posted it on this board once before. I must of missed that thread!
Thnx
Old Jul 3, 2007 | 12:48 AM
Micah1234's Avatar
Micah1234
Default RE: starter
I unbolted the starter but it's just not coming through the bottom. Can you give me a better explanation on getting this sucker out of here using shanes way, that would be great.
thanks
micah
Old Jul 3, 2007 | 12:53 AM
Micah1234's Avatar
Micah1234
Default RE: starter
Today i also found out that about 10 minutes from my house is Second Generation Mustang.
279 Briar View Drive
P.O. Box 429
Leola, PA 17540
Phone: 717-656-8081
New (NOS), Used ("experienced"), and Reproduction parts for Mustang II's.
Old Jul 3, 2007 | 01:03 AM
gwb16's Avatar
gwb16
Default RE: starter
Micah,
You're going to need to remove the motor mount from the frame and block, support the engine with a jack and a block of wood under the harmonic balancer, the starter will slide straight forward, right past where the motor mount was installed, yes you're darn right that's one hell of a pain the a$$! It will not drop down anywhere near the area that your picture shows.....
Wayne
Old Jul 3, 2007 | 01:49 AM
my77stang's Avatar
my77stang
Default RE: starter
yup.... and im pretty sure i have actually BEEN to second generation mustang. its either a building half in the middle of nowhere, or its a guyas house and his garage was like the basement or something.
lemmie know - both places were good people
Old Jul 3, 2007 | 07:13 PM
73 Sportroof's Avatar
73 Sportroof
Default RE: starter
You may try my way. Two bolts hold the rack on for the steering, pull those out and thenthe rack will swing down out of the way and the starter will squeeze through there. It is still tight but it fits. I changed mine on soft ground and didn't have a good jack handy.
Old Jul 3, 2007 | 08:43 PM
Micah1234's Avatar
Micah1234
Default RE: starter
Hey to do it Doug's way do I unbolt the bolts were the red circles are and were the blue circle is, is that bolted to anything? The Motor mount bolts are rusted on and i can't bust them off
