Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
starter
Old Jul 3, 2007 | 09:09 PM
  #21
my77stang's Avatar
my77stang
Default RE: starter
red bolts yes, blue thing no.
arent starters FUN?
Old Jul 3, 2007 | 11:26 PM
  #22
Micah1234's Avatar
Micah1234
Default RE: starter
I took thelug nutsoff do you need ALOT of force to get it to swing down? Do i need to remove the tie rods?
Old Jul 4, 2007 | 12:00 AM
  #23
my77stang's Avatar
my77stang
Default RE: starter
you dont need to remove tie rod ends, but that thing is probably ON there - so its going to need some coaxing
Old Jul 4, 2007 | 02:04 AM
  #24
Micah1234's Avatar
Micah1234
Default RE: starter
I got the rackloosebut now i ran into another problem the Oil pan is in the way and i can get it off the full way. should i drain the oil and take the pan off? While i'm at it i could sand the rust off and paint it.
Old Jul 4, 2007 | 12:41 PM
  #25
my77stang's Avatar
my77stang
Default RE: starter
you'll never get that pan off the car with it in there........ as for the rack,
again, i never did it that way, i always took the motor mount off but if its rusted and your scared to break a bolt that puts you in a stickey situation.
73 sportroof, input on this situation?
Old Jul 4, 2007 | 01:38 PM
  #26
Micah1234's Avatar
Micah1234
Default RE: starter
nvm... the pan is not in the way, i figured out that theres a little rubber part that can bend pass it, however the pinion is holding the right side up. do i have to remove that now?
Old Jul 5, 2007 | 01:23 AM
  #27
my77stang's Avatar
my77stang
Default RE: starter
73 sportroof.... where are you on this [&:]?
Old Jul 5, 2007 | 10:22 AM
  #28
73 Sportroof's Avatar
73 Sportroof
Default RE: starter
I am trying to remember. I did that 13 years ago and I don't own one now. I don't remember having any problem, that is why I suggested it.
I never removed anything else. I just remember swinging it down and it was hanging on the rods. I don't think I had it off the ground, the only jack I had was the stock one and I didn't trust it in the dirt. If yours is off the ground maybe the front end is in a bind hanging there. I hope it works out for you. Let us know.
Old Jul 5, 2007 | 11:59 AM
  #29
my77stang's Avatar
my77stang
Default RE: starter
^ that could very well be
Old Jul 6, 2007 | 12:15 AM
  #30
Micah1234's Avatar
Micah1234
Default RE: starter
HALLELUJAH!!!!! I got that Son of B**** out of there!! Thank you guys for all your great help and thanks for responding within hours.Now I'm gonna take it to the shop and get the motor rebuilt or should i replace it. I heard Jasper Engines is pretty good, any opinions?
Thanks
