HELP! 2006 Mustang GT Cylinder 7 Misfire
Hello. I am new to this forum and I signed up in hopes to get a little help with my 2006 GT.
The issue:
For a couple of months and almost $3000 later, my mustang has had an ongoing issue with a misfire. In every gear (especially 3-5th high rpms) my car starts to sputter and has very little power. I ran a diagnostics on it and came up with p0340 or p0390 code ( i do not remember exactly). I looked at many forums a couple of months back and saw that many people haad a similar problem and the answer was a new alternator. I went to ford service and got a new alternator. I installed it at home and still had a sputter.
The next step was to get my fuel pump tested. Everything was ok. Next I replaced the Fuel Filter since it is easy and cheap... still sputters. Next I upped my fuel pump to 25 PSI to see if it that would solve the issue... still sputters.
A couple of weeks ago I put brand new spark plugs and ignition coil boots on it and still.... SPUTTER!
Today I installed 8 brand new fuel injectors and still my car is sputtering. I am running out of ideas on what the issue could be.
Additional information about my car.
100,500miles
Steeda underdrive pulleys
Bassani SS off road x-pipe
Flowmaster Super 40's
(Installing my Steeda 90mm cold air and SCT BAMA tuner on monday when it arrives ups from AmericanMuscle)
I have replaced my alternator twice
spark plugs and the coils are 2 weeks old
Fuel Injectors are brand new as of today
all vacuums are tight
Any help is appreciated!
Thank you
The issue:
100,500miles
Thank you
If you're positive there's no vacuum leaks, then how positive are you that your exhaust is bolted up tight against the exhaust manifolds? That's the only other thing I can think of besides a typical vacuum leak, and an exhaust leak isn't likely to be cause a misfiring (although I've probably seen it a small handful of times).
I know this is barely helpful, but sometimes the unique or unusual symptoms are the hardest to fix.
Shane
Tried replacing the sensor? If the DTC that often shows up due to the alternator doesn't go away with replacing the alternator, it's a fair bet it's the sensor itself. Cost ya a whoppin $28 and 15mins time.
http://iihs.net/fsm/?dir=10&viewfile=Diagnostic%20Trouble%20Code%20(DT C)%20Charts%20and%20Descriptions.pdf
http://iihs.net/fsm/?dir=237&viewfile=Camshaft%20Position%20(CMP)%20Se nsor%20-%204.6L%20(3V).pdf
http://www.tousleyfordparts.com/part...ITION%20SENSOR
P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
Description: The test fails when the powertrain control module (PCM) can no longer detect the signal
from the camshaft position (CMP) sensor on bank 1.
Possible
Causes:
CMP circuit open
CMP circuit short to GND
CMP circuit short to voltage
SIG RTN open (VR sensor)
CMP GND open (Hall-effect sensor)
CMP circuit short to CMP2 circuit (if equipped)
CMP incorrectly installed (Hall-effect sensor)
Damaged CMP sensor shielding
Damaged CMP sensor
Damaged PCM
Possible
Causes:
CMP circuit open
Damaged CMP sensor
Damaged PCM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
