Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Best intake for Boost.
Old Mar 1, 2006 | 03:01 PM
FoxRod's Avatar
FoxRod
Default RE: Best intake for Boost.
Yeah i have heard of box style manifolds. I know that Comp Cams makes one but who else does? And why is a box manifold so good for boost? How is it different? Sorry to ask so many questions. Just wanna make sure my baby gets only the best. ha ha ha
Old Mar 1, 2006 | 03:11 PM
angcobra's Avatar
angcobra
The box intake will make sure all cylinders are getting the exact same pressure and air supply. I run a box on my 86 and a Trick Flow Track Heat on my 88. For high boost 15# or greater I would go with the box style. I have a downs box on the 86 but I think you could be happy with the Trick Flow or Comp. Not much difference in performance when you are just talking about a box in front of the cylinders.
Old Mar 1, 2006 | 03:39 PM
FoxRod's Avatar
FoxRod
[sm=smiley20.gif][sm=smiley20.gif][sm=smiley20.gif] Cool thanx. So you think the Comp cams box should be relatively good. I was just scared to get that because I thought it looked kinda cheesy with the plastic. But what do I know.
What about the manifold in my first post of this thread. Is that considered a box manifold. It says it is good for turbo's. Plus it is Trcik Flow so it should be a quality product.
Old Mar 2, 2006 | 12:43 PM
angcobra's Avatar
angcobra
ORIGINAL: FoxRod
If I needed a new one, that is the one I would consider.
Old Mar 2, 2006 | 06:10 PM
waxyourboard's Avatar
waxyourboard
you can check out the BBK SSI-R too... http://www.mustang50magazine.com/tec...ake/index.html
Box intakes are good for power adders because the intake velocity is already up where it needs to be to produce power... so you can run a normal engine with a power adder and box intake instead of needing a high-rpm stroker combo to get the intake velocity higher
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
