Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
boost cooler
Old Sep 6, 2006 | 06:53 PM
99roushgt's Avatar
99roushgt
Default RE: boost cooler
yea im close enough though about a hour or so it took me 1 hour and 15 minutes in traffic to get to RET but yea i dont have a pms i just have the SCT chip and Xcal2 which is also a hand held tuner
Old Sep 9, 2006 | 12:21 AM
Justastockmustang's Avatar
Justastockmustang
99roushgt - How do you like the snow meth injection? Has it allowed you to run more boost?
Thanks
Old Sep 9, 2006 | 12:38 AM
99roushgt's Avatar
99roushgt
yea it allows you to run alot more boost as it basically is high octane fuel , it helps prevent detonation and cools the intake air temps , i had tons of success with it on my last car and swore by it, but on my stang i havent had that great of luck with it due to the tuner i had a tuner who never tuned it before try it and just couldnt hack it, i highly reccommend it as well as everyone else with it as long as you have a tuner who is quite skilled in tuning the methanol injection
Old Sep 9, 2006 | 01:16 AM
Justastockmustang
I would like to use it with my kb tune not so much for additional power but just to keep from detonating with a couple more psi. You think I could use it this way without a new tune? 9 psi is right on the edge now and I'd like to get up to 12.
Thanks for the responce!
Old Sep 9, 2006 | 01:27 AM
luckythirteen13's Avatar
luckythirteen13
you need to get it retuned to run meth. without a tune you can actually lose hp
Old Sep 9, 2006 | 12:06 PM
nanaki's Avatar
nanaki
Retired MF Moderator
my tuner ****ed some **** up. he squeezed 50RWHP out of it with an AFR that looksl ike it was drawn with a marker and ruler.
Old Sep 9, 2006 | 03:46 PM
Justastockmustang
I know it would have to be tuned to be optimal with the meth, but I am already running 25 degrees of timing so all that can be done is lean it out some. If I don't run a real high meth ratio it shouldn't make it too rich. I don't really want to lean it out, it's daily driven all day long and would just as soon stay on the safe side. All I want to do is keep detonation down. KB poopoo's any tuning and snow says it should work like this. I would the progressive MAF system so it should put the appropriate amount in for a given boost.
ORIGINAL: luckythirteen13
Old Sep 9, 2006 | 04:13 PM
luckythirteen13
im only running 25* timing because im playing it safe. low timing means low chance of ping. i could easily run another 5* but i dont.
Old Sep 9, 2006 | 04:26 PM
2000GT4.6's Avatar
2000GT4.6
unless it was gonna be big bucks there is no way I would not repair the intercooler. Methanol injection is fine and works well, but no way I would trade an intercooler for it.
Maybe use both?
Old Sep 9, 2006 | 07:20 PM
turbostang21's Avatar
turbostang21
"only" 25* tt[:-] that's pretty aggressive....i run only 18*tt so there's still more power at this boost level
im intercooled w/ meth inj...picked up 40whp on a mustang dyno just spraying it (no tuning). the ic was a bit hot so the #'s are probably a bit higher than they would've been after a cool down but you get the idea. it was enough hp (especially for 300 bucks) i decided to play it safe and not tune for it .
definitely fix your ic or buy a new one
