compucar nitrous?
no link, but i gurantee your talking about the bottle-in-a-bag kit
nothing wrong w/ that kit, thereis room for error since your actually hitting the button manually, and also it will be inconsistent for the same reason.
my buddies stock '95 lightning broke into the 12's w/ that kit. the highest jetting is about 90 hp
and yes, it truly is a 10 minute install, you need to loosen (not remove) and tighten 1 clamp and thats it.
selonoid is mounted on the bottle, the bottle is mounted on a board, and it's all in a gym bag.
Also heard it was a very fast install but you gotta think do i want a 10 min install nitro kit that has to be operated manually with a high possibility you will f*** that motor up someday remember just 1 mistake and boom plus i believe there jets go up to 100 (might be wrong)??? Or spend 1.5 hours to install a very safe system that could possible f**** up your motor but very unlikely?? I think if it were me id spend the extra hour under the hood and buy something that reliable and much more safe.
