Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Tuning after water/methanol install
Old Jan 8, 2007 | 07:07 PM
psi pony's Avatar
psi pony
Default Tuning after water/methanol install
Contemplating getting a water/methanol cooling system, for 300 bucks its definitely worth a shot, but what kind of after installation tuning am I looking at?
thankx
Old Jan 8, 2007 | 09:30 PM
Fuel's Avatar
Fuel
Default RE: Tuning after water/methanol install
i have heard and just heard so let me know if i am wrong but they day that if u don't get it tuned u will just be using it for added detonation protection, but with a tune it will gain u quite a little power, especially if u don't have some sort of intercooler already
Old Jan 8, 2007 | 09:44 PM
nanaki's Avatar
nanaki
Retired MF Moderator
yeah. if untuned or taken to someone who doesn't know how to tune for meth, it won't gain any power. take it to the right shop, and you'll get upwards of 50+RWHP. i got 50RWHP using the cheap 70/30 wiper fluid with the smallest jet. would have been more if i went for the 51/49.
Old Jan 9, 2007 | 12:42 AM
Mike93SVT's Avatar
Mike93SVT
you'll need to pull a little fuel out after it kicks in, it will make you run rich. you'll also be able to run more timing and a little more boost.
Old Jan 9, 2007 | 01:15 AM
luckythirteen13's Avatar
luckythirteen13
youll need to take out fuel from the injectors so you dont run rich. you can lean it out a little too if you want to get agressive with it (i.e. run 12.0:1 afr instead of somewhere around 11.5:1). after the desired afr is hit, then you begin adding timing. id add 3* for the first run and then each run after that add 2* untill you hear ping and then back it down 2*
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
'stangdude
Aug 12, 2015 01:27 PM
