Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Boost reading Differences
Old Jan 25, 2007 | 01:41 PM
kiohio's Avatar
kiohio
From: Nelsontucky OH:Where men R men & the sheep R liars
Default Boost reading Differences
The boost/vac gauge was installed on the car when I got it.
It always read somewhere around 6-8 lbs.
I never paid alot of attn because it's just a DD and it has a small SC on it.
It never read vac, only boost since purchase.
So, while cleaning up the engine compartment I looked for other places to hook it.
It was hooked on the nipple above the TB (hose used to go to the VC).
I moved it from there to the port on the bottom of the upper intake on the drivers side.
Now it shows both. I can't get it out on the road right now.
Will it show a different boost number? And if so was the other place a better place to get it from?
Thanks KO
Old Jan 26, 2007 | 02:49 PM
samseed101's Avatar
samseed101
Default RE: Boost reading Differences
If it was always showing boost and never vacuum, then it was not hooked up right to begin with. The car should only be reading boost levels when you are actually under boost which would generally be at WOT. During normal everyday driving, it should be reading a vacuum because you would be running N/A for all intents and purposes. A supercharged car usually only runs under boost for a few seconds at a time.
Sounds like you have it hooked up to the right place now. Can't really tell if it will read more, less, or the same when under boost. Depends on how many PSI you're actually pushing.
Tivo304
Aug 28, 2023 12:19 PM
2007CalSpec
Dec 13, 2020 11:42 AM
Galactic
Apr 29, 2019 02:56 PM
