Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous Fitting
Old Mar 12, 2007 | 04:43 PM
93WhiteStallion's Avatar
93WhiteStallion
Default Nitrous Fitting
I was wondering what size fitting i need to adapt my fuel rail to the nitrous fuel line
i have a 93 fox
thanks
Old Mar 12, 2007 | 07:06 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Nitrous Fitting
what size nitrous line ? -4 ? -6 ?
you need 1/16" npt male X 1/8" npt female reducer most likely, then a -"X"an fitting X 1/8" npt into the reduecer, then the an line goes on that fitting. i doubt you can find it as 1 piece, you need both.
the reducer will be brass, and the an fitting aluminum(blue)
1/16 X 1/8 is what you need to go into the rain for the fp safety switch , if your gonna use one, then you need tee off the rail then use both ports, 1 fuel feed, 1 switch
jwog666
Dec 27, 2021 08:09 PM
mustangheaven
Jan 3, 2016 11:20 AM
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
mdg
Oct 1, 2015 07:04 AM
