100 shot
100 shot
wats up everyone i want to use a 100 shot or 150 on my 4.6L stroker but not sure wat set up to use should i use a dry or wet shot, should i get a plate kit, or where should i put the nozzle before or after the TB. which one is easier to keep hiden
thanks for the help
thanks for the help
RE: 100 shot
I have a 125 Shot Dry N.O.S setup running on my mustang right now. All I have is a tune and upgraded fuel pump. IF you are looking at hiding the install (like I did) I would not go with a plate system. I would go with the nozzle in the bottom half of the intake inlet pipe and then put the solenoid in the fenderwall as well. When I go through tech at the local track they don't notice the stuff underthe hood just the bottle in the trunk. I have even seen installs where they put a smaller bottle in the door panel as well.
RE: 100 shot
No, it is not illegal to have it installed. It is however illegal to have the bottle open while driving on the streets. I have been pulled over several times and I just make sure the bottle is closed when I am off-track. Remember you have to give them permission to or probably cause to search your car in the first place. If you do have a problem and they question you about it just tell them that you have to have the bottle secured in the car and that is why it is hooked up.
jwog666
12-27-2021 08:09 PM
