Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
i meant will 5.0 work on
Old Aug 22, 2003 | 03:48 AM
tjs57tpi's Avatar
tjs57tpi
Default i meant will 5.0 work on
what i really meant isis the supercharger the same from a 5.0 as a 4.6, i heard its just a different mounting bracket, supposedly it sits backwards on a 4.6, so i tr to call vortech and no answer.....stereotypical help line, but whatever, the first time when i called to see if an 02 would work ona 98 they were very helpful
Old Aug 22, 2003 | 02:25 PM
jeep45238's Avatar
jeep45238
I ♥ Acer
If it's a centrifugal system, then yes. The only differences that I can see would be the mounting bracket, piping, and electronics if it comes with fuel management (I'm not sure on that last one since I don't know if they use the same computers).
Centrifugal blowers are pretty much non-car-specific. Same with juice. It's just that with swapping into another car, certain parts will have to be custom to get it to fit.
Old Aug 22, 2003 | 02:29 PM
Buzzstang's Avatar
Buzzstang
the sc should work just need the rest of it to hook it up to the 4.6
Old Aug 25, 2003 | 03:00 AM
tjs57tpi's Avatar
tjs57tpi
what about 5.0 injectors? will they work ina 4.6?
Old Aug 25, 2003 | 03:26 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Assuming they physically fit, you have o-rings that will seal properly, can tap into your fuel rail, and will accept signals from you computer, sure!
But that goes for any/all injectors.
Old Aug 25, 2003 | 02:43 PM
stang574's Avatar
stang574
Yea the fuel injectors will work fine. Although they are the same size injectors.
Old Aug 26, 2003 | 03:37 AM
tjs57tpi's Avatar
tjs57tpi
no, he has bigger sized ones i would buy off him with the blower, i forget what size.,....what size are the stock ones?
Old Aug 26, 2003 | 02:49 PM
stang574's Avatar
stang574
Their 19 lb injectors, thats what comes on stock mustangs. 5.0s and 4.6's.
Nurdyguy
Jan 20, 2025 04:38 PM
waid302
Sep 14, 2015 11:19 AM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 1, 2015 08:16 PM
CarrieS
Sep 1, 2015 01:00 PM
