tuning car
tuning car
i have a 96 mustang gt. i had a vortech v2 running 12psi. and ended up blowing a motor. i have an sct tuner and i put a new motor it without the supercharger and put the stock air meter and fuel injectors back in and returned the computer back to stock. it is still running very rich though. i dont really understand because the computer isstock and the stock injectors are on. the only thing is i have a bigger fuel pump but that should not affect anything. the only other thing i can think of is the mass air meter. canyou program the ACTUAL air meter or is everything on the computer? i cannot figure out why it would be running so rich. thanks.
RE: tuning car
It's your MAF. The one you have now is calibrated for the 42 lb injectors. You need to replace it with a stock one or reprogram your computer at the dyno. Why did you take the charger off? Why not just back the boost down to 10 lbs and ride?
RE: tuning car
ORIGINAL: contentsunderpressur
Give it some time for the computer to relearn...that's normal. Also, double check your fuel pressure. If your larger pump is increasing your fuel pressure, then it's going to force more fuel through the injectors at any given PW.
xbmx89
Texas Regional Chapter
11-10-2015 10:43 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
