Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
before something goes wrong
Old Jul 1, 2007 | 01:18 AM
MAKDAGR8's Avatar
MAKDAGR8
Default before something goes wrong
im boout to run my 75 shot for the first time and i had some questions?
1. can I purge the line without getting a purge kit?
2.how long do i have to leave the bottle heater on before its prime?
3. do i spray on first or wait till second? i have a WOT switch
4.any one every heard of top gun nitrous systems?
THANX IN ADVANCE
Old Jul 1, 2007 | 01:37 AM
nitrous_fed_03gt's Avatar
nitrous_fed_03gt
Default RE: before something goes wrong
1.no
2.you can spray anytime you want. the ideal psi window you are looking for to get your kits full potential is 950-1200
3.you can spray in first, just dont do it any sooner than 2800-3000 rpms
4. no
Old Jul 1, 2007 | 08:57 AM
Willem_Black's Avatar
Willem_Black
Ok, while my Nitrous nowledge is limited, I've been reading up on this for about a year now, and have been to several forums looking to put it on both my last car, and this one. The one thing I would suggest if you don't already have it, and since you didn't specifically mention it I'm assuming you don't, is a window switch. Like c498944484 said, spraying before 3k rpms is bad.....a window switch will keep that from happening. Good luck, and have fun with the nitrous.
Old Jul 1, 2007 | 04:02 PM
96mod289's Avatar
96mod289
1. if you are just hooking it up you could take the line off and crack the bottle open- cleans out any dirt that could be in line. After that youcant purge to get all liquidin theline with out a purge.
2. Get a pressure guage and keep it in the 950-1200 range- if yourheater is a thermostat type then it will shut off at 85 degrees
3.I wouldnt chance it unless you have a window switch- rpms climb quick with 4.10's and nitrous
4. nope
Old Jul 2, 2007 | 07:05 PM
nitrous_bob's Avatar
nitrous_bob
just activate it and goose it once for about a full second, that will make you ready for a run
when the bottle is at leats luke warm to the touch, 65*-70* is ok, the pressure should be fine....85* is better
i launch on it and spray through every gear and i don't lift unless i miss a gear
yeah i've heard of it i think, there are a ton of different makers out there.
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
