which pulley should i use?
dropped my car off today to get the vortech installed..which pulley should i have them put on the 8lb pulley or 12lb? which one would you guys recommend..im not trying to blow up my engine lol but i want the power
RE: which pulley should i use?
ORIGINAL: k2boarder3187
what size is the 10lb pulley?
well my v2sq is being installed right now so i dont knwo the exact hp numbers yet butthe guy i bought it from had a 2.87 pulley and a 3.60 pulley...i told the shop to put on the 3.60 so we willl see what numbers i get with the v2sq, my list of mods and the tune. then i guess i will go from there..im debating on a smaller pulley, a powerpipe or a powerpipe with a slightly smaller pulley
3.60 is what you need....its 6-8psi. 3.33 is 10-12 psi.......and 3.12 is 12-14psi
you cant just run however much boost you want trying to hit a specific HP goal. Detonation comes into play after so much depending on if you have an intercooler or not and how much timing is pulled. Too much timing pulled will cause driveablility problems. The reason why you cant run alot of boost is because of your motors stock compression ratio. If you lowered your compression ratio then you could run alot of boost. But say you tried to run 15psi on stock compression looking for 400whp, it wouldnt be possible because of detonation even if it were intercooled or not.
it all depends on what you have done. i've seen guys running 10psi on a 3.6 and others running 6-7psi on a 3.6 pulley. intake, fuel, exhaust and other factors will determine how much boost you have. try the3.6 first so you have a baseline of what kind of boost your going to make.
10, 12lb, 287, 310, change, mustang, pulley, pulleys, size, supercharger, superchargers, underpulley, v6, vortech
