Magnaflow catback for 94 GT
Anybody familiar with this application? I listened to the sound clips on Magnaflow's site and they sound awesome. It's hard to tell how loud it will be in real life though. I like the increase in power and torque that they show and also the enhance exhaust note however, I'd still like to able to listen to my stereo at moderate volume. I had a Dynomax super turbo cat back system which was ok except for the resonance at about 1800 rpm which was pretty much at my highway crusing speed.
RE: Magnaflow catback for 94 GT
But you have a V6 with a single inlet....
On a GT 5.0 with dual exhaust, even with the stock midpipe it's going to be loud and sound good. The best part about Magnaflows is the no-drone garbage, you can have a conversation or ride around with the windows up and not go deaf.
You were right Dan. I installed the system this weekend and it sounds good. It is quieter than I thought it would be considering the mufflers are a straight through design. It is actually quieter in the car than the Dynomax super turbo system I had on years ago. Aside from the factory header which is a bit restrictive, it is not hard to see why the stock H-pipe causes quite a bit of restriction. At least on mine (94 GT) the H=pipe necks down quite a bit...from 2.5 inch diamter to what looks like about 2 inch diameter right before the secondary cat. I am sure that an aftermarket H or X pipe with a constant diameter and high flow cat's would make a big difference in performance and sound. I assume that the later years Ford straightened out this neck down thing since to me it makes no sense. All in all I think it sounds like a GT should sound right off the showroom floor....not too loud but does have some authority with it's deep tone.
panic
09-10-2015 05:56 PM
