is it time for the KB yet?
You can see my mods in my sig......im thinking about springs and tokico d-specs next then do you think its time to do some mad saving for a 2.6l KB or are there other things i need to do first?
thanks!
thanks!
RE: is it time for the KB yet?
Looks good. After you do the rest of your suspension you should be set. The only thing I can think of is sub frame connectors. You need all the help you can get putting that power to the ground
i havent seen a 2.8l KB for the 05+ mustangs.....and i thought the 2.6 was supposed to fit under our stock hood.....well ill go check.....just one more Q. would delete plates help or r they not worth it if u get a s/c?
Im not sure how complete the kit comes, but i would definitly look at upgrading your throttle body, Air meter,and fuel pump and injectors ahead of time or you can wait and do all that when you put the supercharger on, its the only way you will get the full potential.
Mate of mine has a KB on his 05 GT. We're getting our cars dynotuned together saturday. He was at 500 rwtq. He just put in a 13lb pulley and done some other stuff. Hence the retune. I have an 11lb spring and boost controller, good for 20 lbs, but will not touch the controller untilshort block is changed.We both still have stock motors. I am planning on built short block in October. Until then everyday that the motor stays whole....is a good day. By the way, the KB looks awesome underhis stockhood.
I'm glad to hear ur buddy likes his kb....does he have a 2.4 or 2.6l....i was thinking about goin turbo but i already had my headers on and loved the sound so much i dont want to change'em...im thinkin a big 2.6l KB is the next best thing.....let me know what ur buddy dyno's at...im anxious lo hear.
thx for all the input guys i could still use more if yall have it
Nathan
Nathan
lol. yup build your engine first then get a kb 2.6
wasted money if your only running 8psi
or you could tt for almost same price.lmao
but major supporting mods to go with it
i havent seen any tt setups ecxept for sts but i personally dont like the rear mount turbo system....im sure its a great setup but i want people to see it when i pop the hood. anyways im sure when alot of tt systems do come out im not goin to get'em for the same price as a KB. but i could be wrong!
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
