Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
non intercooled boost?
Old Oct 26, 2007 | 04:44 PM
NYstang's Avatar
NYstang
MF Staff Snitch
Default non intercooled boost?
how much boost is too much without an intercooler? a friend of mine wants to put a Vortech S-trim on his LT1, but doesnt have the intercooler...
Old Oct 26, 2007 | 10:22 PM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: non intercooled boost?
vortech tech line should be able to help you im not sure with an LT
Old Oct 27, 2007 | 10:41 AM
393Bird's Avatar
393Bird
The guys running in NMRA Renegade class are turning mid 8s in the 1/4. There rules do not allow any inner coolers, and they are running YSi SCs cranking out 30-38 psi. So it all depends on the octane gas, the timing, A/F ratios, cylinder heads, plugs etc.
Old Oct 27, 2007 | 12:09 PM
nanaki's Avatar
nanaki
Retired MF Moderator
i ran 10psi non-cooled for awhile and had no problems. just make sure he gets it tuned.
Old Oct 27, 2007 | 12:22 PM
zuluracerx's Avatar
zuluracerx
Mine is at the dyno this week. I should be able to report some new numbers, A/F's, timing, boost, etc. I am not running an intercooler with my Vortech T trim. I am shooting for 15 lbs of boost with 100 octane tune using Big Stuff 3 programmable EFI.
Old Oct 27, 2007 | 12:59 PM
nanaki's Avatar
nanaki
if you have a 2.60 pulley, you'll easily hit 16psi. i'm only pushing 13psi on my T trim with a 2.60 with the intercooler i have now. i was running 16psi on my S trim with no intercooler, but had methanol injection. i'm going to get a lower crank pulley so i can get my boost back up to 16psi. the T trim is amazing. much quieter than my old V2 S trim and makes more power at 13psi than the S did at 16.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Bokeo
Oct 10, 2015 08:28 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
