maf meter
can i use the same one that is on my car n/a with my twin turbo setup is there a specific spot i should put it? i was thinkinat the end of the straight pipe thats is gonna run from front passenger bumper corner to the air intake hole in the fender so it isnt right after a bend does that sound like a good spot?
answer one is more then likely no your not going to want to run a stock MAF, you will want a blow through one, my suggestion is PMAS they make a good one for turbo cars, generally a good place to put the MAF is around 8-12 inches away from the throttle body if possible, in your first pic in your sig thats generally a good position for the MAF
jwog666
Dec 27, 2021 08:09 PM
