Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
ProCharger PSI...
Old Nov 25, 2007 | 08:01 AM
  #21
iraziel's Avatar
iraziel
Default RE: ProCharger PSI...
ORIGINAL: moocow_v
you can get the kit from pro charger, to run an individual belt, as for blower psi, dont listen to what most people will tell you because there are quite a few factors there no given chart that says hay a 3.1 pulley will give EVERYONE xx Psi boost, to find the pulley you should use heres what i did, calculate compression ratio, find the most accurate altitude of where you live, call pro charger tech line tell them what your working with the boost lvls you want to achieve, they are pretty much spot on, to put in perspective, i told them what i was and that im at 5,800 feet above sea lvl and i wanted 10lbs of boost no more, put the car on the dyno max boost psi reached was 10.2 psi
Im in Alb, NM, elev: apprx 5400 above sea lvl, what size did they give you?
Old Nov 25, 2007 | 11:51 AM
  #22
Stroked N ProCharged's Avatar
Ummmm like 8.5 to 1????
Old Nov 25, 2007 | 12:32 PM
  #23
contentsunderpressur's Avatar
I bet you'd be ok to run the 2.9 pulley. You have way more cubic inchs than a 4.6 and my buddy was running a 2.75 pulley witha 8 rib setup making 19 lbs of boost on pump gas with 8.5 compression. You should be ok for sure to run the 2.9.
Old Nov 25, 2007 | 12:39 PM
  #24
I would LOVE to Make closer to 20 PSI.. That would be great..
I would need like what 50 lb Injectors??
Old Nov 25, 2007 | 08:50 PM
  #25
I'd use 60s.
Old Nov 26, 2007 | 12:05 AM
  #26
P.S.I.cho's Avatar
P.S.I.cho
hope you dont have the stock cast iron block or your in trouble, but anyways for 700 hp any injector bigger then 54.7 is recomended so i would shoot for 60 # injectors M-9593-LU60* make sure your running the recomeneded 39 psi at the test port, your gonna need a new fuel pump thats a given, possibly a fuel pressure regulator, good idea to put one on even if your not sure if youll need it makes tuning a little more easy
Old Dec 5, 2007 | 08:21 PM
  #27
Is there anyone in the Philadelphia area that has alot of knowledge
withBlown Mustangs like mine??? Mine needs a decent amount of
work to Hit My goal Hp..
But for now I would like someone that has the knowledge about
blown Mustangs...
Thanx,
Rob
Stroked n Procharged
articman
Jun 21, 2018 11:45 PM
Granatelli Sales
Mar 21, 2016 06:16 PM
Dragonus18
Sep 9, 2015 01:21 AM
Black_GT_02
Aug 20, 2015 01:26 PM
Dearborn5.0
Aug 9, 2004 10:42 AM
