Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
boost
Old Oct 8, 2003 | 11:30 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Default boost
12 psi? You like to rebuild motors a lot? Or do you have access to a kick-*** dyno tuner?
If you don't on either or both accounts, 12 psi on a stock motor from any blower is not a smart move.
Bigger hassle? Let's see.......bolting on this s**t and tuning it or swaping out heads on an OHV set up.........neither's cake.
Old Oct 8, 2003 | 02:20 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default boost
12 is alot of boost for a stock bottom end, but Iveheard ofpeople running 15 lbs boost on a stock 4.6 bottom end and not having any problems, since your intercooled with an Procharger you wont have any problem with detonation with a good tune, your problem would be worrying about breaking rods. Like I said earlier Im gonna be running 10 lbs boost with a non-intercooled vortech. Im not worried. 12 with and ATI wouldn't worry me either, but then again I can rebuild my motor if necessary for just the cost of parts, can you?
Old Oct 9, 2003 | 02:44 PM
beezy's Avatar
beezy
Default boost
I am not planning on adding the supercharger anytime soon, I wanted to learn a lot more before doing any hardcore modifications.</P>
</P>
What kind of boost does the 03 cobra's s/c put out?</P>
Old Oct 9, 2003 | 05:01 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default boost
I think around8 lbs. Not 100% sure.
Old Oct 9, 2003 | 05:36 PM
vfast's Avatar
vfast
I ♥ Acer
Default boost
just put a vortech on it running around 6-8 pounds...put a nice set of alum heads and a nice cam and you'll be around what 12-14 psi will give ya...and there won't be any problems..run 15psi and invest on several sets of head gaskets...unless you o-ring the heads..then you sooner or later have a rod kick out...6-8 psi is all you need with out the over priced intercooler....
Old Oct 10, 2003 | 04:56 AM
beezy's Avatar
beezy
Default boost
Thanks for all the advice guys</P>
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
