Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
water/methanol injection
Old Mar 12, 2008 | 08:02 AM
treekiller42's Avatar
treekiller42
Default water/methanol injection
i was wondering if anyone knew anything about water/methanol injection on a supercharged motor.Would it be worth it to add it to my car?
Old Mar 12, 2008 | 08:16 AM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: water/methanol injection
i picked up 40RWHP adding it to my car. i've since then upgraded to a 3 core. definitely worth it for a cheap intercooler.
Old Mar 16, 2008 | 10:17 PM
treekiller42
how often would i have to refill it and would it be worth it adding it to a daily driver.
Old Mar 17, 2008 | 05:23 AM
nanaki's Avatar
nanaki
depends on your foot. i went weeks at a time without having to touch it.
Old Mar 17, 2008 | 03:10 PM
only90s's Avatar
only90s
ORIGINAL: treekiller42
If you are on the boost all the time...you will go through the Meth pretty quick....if you drive the car normal and only hit the boost occasionally it might last until you need to fill the gas tank up....
IMO it is a pain in the *** for a DD...
works great for me...but mine is a weekend toy
Old Mar 17, 2008 | 08:17 PM
floodzilla's Avatar
floodzilla
Yeah i go througha bottle of wiper fluid like once every 2 weeks. i dont care though, its only a couple bucks for a gallon from walmart. (wiper fluid, cheap and it works)
Old Mar 18, 2008 | 03:50 AM
2000AZ5.0GT's Avatar
2000AZ5.0GT
It's really good if you have a tuner that knows how to tune for it, and if you fill it up every chance you get. I top mine off every time I fill the gas tank, so once every 150miles or so.
Personally, I think it's very worth it, as long as you do it safely. I added the J&S safeguard to it which reduces timing if it senses that it's out of methanol, but I will soon be adding a FMIC to replace it, because I don't want to risk it failing on me. I think depending on how much you're running, you should probably be okay, as long as your tuner doesn't put you on the ragged edge of safety. There's a sticky on the top of the page about it, it probably has more information than I or any one of the other members could give you personally, other than a word of mouth reccomendation
jwog666
Dec 27, 2021 08:09 PM
rksnow1
Sep 14, 2015 08:46 PM
MusBBad95
Aug 17, 2015 09:39 PM
TheGmKiller331
Feb 18, 2004 12:55 AM
