supercharger causing idle problem??
I have a S/D 88 mustang and i have a couple mods, Off road X pipe, BBk Headers, Msd Ignition, Ported and polished stock headers, and a V1 vortech super charger boosting at 8 lbs. i dont have a cam but im having a really bad idle problem and im wondering if the supercharger could be to blame. any help, ideas, or direction?
You def. need a tune. However since your mods are minimal, the supercharger should not affect your idle. Check to make sure your MAF is securely tightened. Any air escaping will cause a terrible idle(happend to me).
he doesn't have a maf, speed density.
Honestly you'll probably get more help if you post this question in the speed density section: https://mustangforums.com/forum/speed-density-carb-ssp-section-45/
Check this site out: http://www.muscularmustangs.com/iac.php
There are all the common causes for idle problems. Look into all of them, just ignore part 5 (cleaning the maf) as it doesn't apply to you.
musnicki
Sep 23, 2015 07:11 AM
Sep 3, 2015 07:14 PM
00, 1995, 50, 86, bad, common, f250, fluctuation, ford, idle, mustang, problems, supercharged, supercharger, vortech
