Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Additional needs with SC?
Old Mar 6, 2009 | 07:24 AM
Bone32's Avatar
Bone32
Default Additional needs with SC?
Hey guys. I'm going to get a Vortech S-1 This summer once I have the money, but is there any other mods that need to be done to the car? Mines an 02GT and all I have done right now is a Cat-Back system. I plan on going with gears and more bolt ons after I get the SC unless its absolutely needed before hand..
Thanks!
Old Mar 7, 2009 | 06:35 AM
Obsequious1's Avatar
Obsequious1
JUST STAY IN THE 8 PSI RANGE AND YOU SHOULD BE FINE. I'M RUNNING 10 PSI WITH SOME BOLT ONS, I DON'T RACE MY CAR ON THE WEEKENDS BUT I DO LIKE TO GET ON IT ONCE IN A WHILE. I BURN A QT. OF OIL EVERY 1000 MILES @ 60.000 MILE ON THE CLOCK. THIS SUMMER I PLAN ON BUYING A RACE BLOCK AND A UPGRADE ON THE BLOWER, MAYBE 15 TO 20 PSI , SO I NEED FORGED INTERNALS.
Old Mar 7, 2009 | 02:14 PM
Nrre's Avatar
Nrre
Don't forget the Fuel upgrades. If you are just going with 8psi you should only need an SVT Focus pump. This is all I plan on with my 02 GT. I to only have a cat-back and next mod will either be 4.10's or I'll just save up for the supercharger setup.
Old Mar 9, 2009 | 01:00 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
You will also need to change out your stock injectors and recommend 42 lbs injectors and definitely get gears 4.10s and a short throw shifter.
Old Mar 10, 2009 | 03:04 AM
Nrre's Avatar
Nrre
i would do research on gears. you dont NEED them or the Short throw shifter(STS) but they would help a lot.
I've grinded the gears once or twice when i get on it with the stock shifter. As for Gears, many suggest only 3.73's if you are going F/I. Unless you have an Auto than some say 4.10's.
if i could id go with 4.56's on my 5spd just because it sounds more beastly =P especially if/when I go F/I
mtgldr
Feb 3, 2024 09:00 PM
b8checker
Oct 8, 2015 12:55 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
b8checker
Sep 30, 2015 07:11 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
