Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
stroker kits
Old Nov 30, 2003 | 12:28 AM
Ifbbpro85's Avatar
Ifbbpro85
Default stroker kits
I was wondering if i just need a 393 custom crank to make my 351C a 393 Stroker motor...i know about the 302 base kits....but not the 351.....is this all i need or the whole package.....pistons,rods,crank,rings......????</P>
Old Nov 30, 2003 | 01:30 PM
Ifbbpro85's Avatar
Ifbbpro85
sorry about all of the post i kept on getting errors and crap wasnt sure if it posted.....guess it did
Old Dec 1, 2003 | 05:10 AM
baha's Avatar
baha
Hi, all you have to do is change the crank, just like the 302 to 331 stroker.
Baha
Old Dec 1, 2003 | 05:18 AM
baha's Avatar
baha
I forgot to tell you.. I'm not sure about this but 351C blocks are a little different from 351Ws, it might need some machining to fit the crank.
Baha
Old Dec 6, 2003 | 01:20 AM
mustang50's Avatar
mustang50
The block obviously needs to be machined, which calls for a complete stroker kit. Pistons, Rods, and crank. Go with a 408 instead.
Old Dec 6, 2003 | 02:54 AM
baha's Avatar
baha
If you are gonna go over 400ci, how about a 427ci? you can use extra torque over the 408ci plus a legendary name.<img border="0" src=smileys/smiley16.gif border="0">
Baha
Old Dec 6, 2003 | 02:56 AM
mustang50's Avatar
mustang50
then why not a 514?
Old Dec 6, 2003 | 03:19 AM
baha's Avatar
baha
Cause the max you can go with 351s is 427, 514 is a 460 block stroker, in this case you can go up to 600ci!! about 10 liters!! just imagine having all that torque between the fenders of your Mustang! BUT.. you need some serious suspention, serious trans,... all serious to handle all that power, in my opinion, you don't need all that torque, 427 is more than enough, you can have 500+ horsepower easily with street heads and pump gas without the extra cost of 460 block and parts. One more thing: with a heavy engine like that, you will have very bad handling.
Baha
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
