Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Stroker?
Old Sep 9, 2005 | 11:58 AM
metaldrummer's Avatar
metaldrummer
Default Stroker?
I was thinking about swaping my 2 valve for a 4 valve on my 2002 s281, forging the internals and then slapping on a huge KB 2.2 blowzilla but the more i think about it, the more expensive the whole process sounds -and time consuming. I found a stroker kit here: http://www.coasthigh.com/ (scroll all the way down, its the 4.6 street fighter or maybe the street fighter pro) anyway, i was wondering what exactly a stroker is and what kind of power id see from it. I know the kit comes with forged rods crankshaft and pistons so id be able to run a ton of boost. Can someone tell me exactly what the kit is/does and if its worth it?
Old Sep 9, 2005 | 12:09 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Stroker?
A stroker increases the size of your engine by making the stroke on the crank shaft longer. As for running a ton of boost, just because it has forged internals does not always mean you just run tons of boost. You need to look at compression ratio and the cam profiles in order to figure out how much boost you can run.
Old Sep 9, 2005 | 12:24 PM
metaldrummer
ok sorry, i should have cleared that up: I dont want to run a "ton" of boost, more like 12 psi at high rpm -definitely nothing like 20 lbs because that would just be rediculous.
a few more questions: if i got the stroker, how would it affect my gas mileage? would i still be able to install basic 4.6 L parts even though my engine would be a 5.1 L? if not, how would i get parts for a 5.1 L (ive never seen then anywhere before)?
Old Sep 9, 2005 | 01:09 PM
JD1969's Avatar
JD1969
I would stay less than 10 psi with motor and the tune will be critical. You can still use your heads and all the external accesories, it's basicly just the interanls that are changed.
Old Sep 12, 2005 | 12:11 AM
91stang's Avatar
91stang
does stroking an enigne change the compreesion ratio?
Old Sep 12, 2005 | 04:56 PM
JD1969's Avatar
JD1969
ORIGINAL: 91stang
Depending on the head/piston/gasket used yes it can. If all other things are left the same, increasing just the stroke will increase the compression, but in reality that never happens as strokers require a piston change.
Old Sep 12, 2005 | 05:18 PM
91stang's Avatar
91stang
i was looking at the dss racing 331 stroker kit with AFR 185cc heads
the storker kit comes with...
331Pro-Lite Series Kits
includes: DSS Pro-Lite Series Pistons, Forged I-Beam rods, cast steel crankshaft, moly rings, tri-metal rod and main bearings.
could yall help me. i'm not really sure what the numbers mean...
Pro-Lite Pistons -3cc Flat Top/Inline, Pro-Lite Pistons -13cc Max Quench/Inline, Pro-Lite Pistons -3cc Flat Top/Twisted Wedge, Pro-Lite Pistons -13cc Max Quench/Twisted Wedge, Pro-Lite Pistons -18cc Max Quench/Inline/Twisted Wedge
thanks
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
kevin02
39
May 22, 2004 01:39 PM
95_GT_Stang
Apr 10, 2004 04:39 PM
