Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Paxton 2200sl Lower Radiator Hose...
Old 07-12-2021, 08:42 AM
jcook1313
jcook1313's Avatar
Default Paxton 2200sl Lower Radiator Hose...
I'm installing a Paxton 2200 SL on a 2014 Mustang GT/CS. I've run into a small problem. The instructions say to flip the lower radiator hose. I did that but now the air box doesn't seem to fit. It sits on top of the hose and won't lit it sit as low as it needs to. I flipped it back around but now it seems too close to the alternator pulley and will likely rub a hole it. Has anyone run into this issue? Is it just a matter of maneuvering the charge air cooler ducting around? Is there another radiator hose someone found that would be a better fit? Any help would be appreciated.
jcook1313 is offline
Jfsram
10-14-2011 07:58 PM
ElSuperPinto
Mustang II Section
02-09-2011 10:35 AM
scootchu
15
06-01-2009 07:14 PM
traxxton
06-28-2008 10:31 PM
Sean W.
08-20-2006 10:36 AM
Quick Reply: Paxton 2200sl Lower Radiator Hose...
