Exhaust leaks?
Exhaust leaks?
Hi,</P>
If you want to check for an exhaust leak, the easiest way to do so is by getting a rag or something to use, to put your hand over the tailpipe/s. Than, after 2-3 seconds of holding it,let off, and if it builds up pressure your fine, and if it doesn't build up pressure than you have a leak. Now that you know you have a leak,you can narrow itdown were it is by visual checking first and than if you cant find it that way. Get a friend to put his hand on the exhaust pipe/s fora second or 2and listen for a hissing sound and sometimes you can actually seea liquidcoming out or see the gap.</P>
Exhaust leaks?
mostly you can tell just by the way it soundsif ya rev it up and ya hear a hiss from anywhere other than the rear of your car its a leak you just havta find where its comming from... most common spots are where ya olt everything up to. lol</P>
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
