Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
running with nitrous
Old Feb 12, 2006 | 09:52 PM
96mod289's Avatar
96mod289
Default running with nitrous
i know this will sound like a newbe but i was wonderig if i have nitrous on my 96 gt auto with a window switch. can i basicaly turn it on and use it through the entire 1/4 mile start to stop or not. also i have heard not to spray in o/d is that true
Old Feb 12, 2006 | 10:49 PM
Car_Ramrod's Avatar
Car_Ramrod
Default RE: running with nitrous
depends on other mods and your tires...you may spin thru 1st if you use it the whole 1/4 mile. if the window switch has a 1st gear lockout, then yes use it the whole 1/4 definitely. and yes...NEVER spray in o/d. unless you want a new car.
Old Feb 12, 2006 | 11:10 PM
nitrous_bob's Avatar
nitrous_bob
yeah you'll be fine.
what gears do you have? w/ 3.08's and an aod i wouldn't.....get the r's up a bit first.
i sprayed my aod '90 lx 'vert (15.10's NA) from the hole and all the way on a zex dry 100 kit. it ran 13.60's
my 5-speed cars, i full throttle shift on the juice and it's all good. launch from the hole always, but i have 4.10's and r's climb plenty fast enuff.
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
