HOW TO: Front Swaybar Install
Link to thread with install pics and FAQ's.
https://mustangforums.com/m_1670743/...tm.htm#1670743
***All new comments please reply in this thread so it stays in this section.***
RE: Front Swaybar Install
ok i just picked up a GT front sway bar.. will the stock V6 brackets work!?!? i know the bar is thicker.. but ford may have used the same brackets and just used more bushing to fillthe space??.. i dont nkow..
ORIGINAL: blackfoot
the bushings are on the bar already.. its if the stock bracket will work with the new bar..
is make one bracket... If you want, I'll go run out to the garage real quick and see how the 4.0 bushing with bracket fits over my
Hellwig.. (which is definately GT spec)
lol.. you made me verrrry curious. Soooo, I had to go check!
Had to cut the factory bushing off sway with a boxcutter. (Easy )
(Hellwig already cuts them for you so they slide right on)
Slid under Pony and the bushing "does" go over the new sway... (Pic 1)
But, the bracket "somewhat" fits over the bushing.. (Pic 2)
I don't know.. unless I knew the diameter of the GT bushing, I would measure and see if its the same
for the 4.0 bracket.
[IMG]local://upfiles/19936/1E85CB7E20D54EC1B7273A91762F26CD.jpg[/IMG]
[IMG]local://upfiles/19936/B2C906D5254D4CE6AB5A8FDC5A4F9AC1.jpg[/IMG]
ORIGINAL: blackfoot
turns out the brackets are the same for the GT as they are for hte V6... they just use different bushings with different size ID, but have the same OD
now i got loads of spare timework ahead forme.. i have to pull the heads off my 1970.. shes burning water.. (headgasket)...i want to pull the motor out ,and a more aggressive cam in it while im at it, and re-paint is ford blue.. the mild cam in it has the same duration but more lift... but my dad wants me to just do the gaskets then in the fall do what i want with it :P..
then i have to cut my rear bumper for my duals
then i also have to install the GT sway bar
09-01-2015 08:16 PM
