Adjustable UCA
Adjustable UCA
So i was thinking of going with these UCAs from steeda http://www.steeda.com/images/555-4105-175.jpg Anyone have them or have any suggestions/comments. btw, the reason im thiinking of going with UCA is because the non adj LCAs look awesome http://www.steeda.com/images/0506_bi...ntrol_arms.jpg , and so to be able to adj (pinion angle etc) i can do adj UCA.
Also, how hard is it to install the LCAs and UCAs. How long does it take. Thanks in advance!
RE: Adjustable UCA
I have the UCA that you are asking about. I have had no problem with it and have been very satisfied. It will be tricky to change unless you have access to a lift. It has held up well to a bunch of hard launches at the track. The lowers that you show by Steeda, i would think twice about. There are a few higher powered cars that have broken them. I went with adjustable tubular lowers and they have been fine. The lowers are very easy to change.
RE: Adjustable UCA
Thanx MusiccityGT! Yeah im also considering the metco http://jlttruecoldair.com/zencart/in...products_id=92 I would go with tubular lowers, but the billet looks soo good. so just out of curiousity, why did you do adj UCAs and adj LCAs? Thanx
