Removing LCA'S
Old Sep 13, 2006 | 12:54 AM
05 Ricky's Avatar
05 Ricky
Default Removing LCA'S
Are you guy's cutting the the stockers off or removing the e-brake cable then removing. I cant believe they ran the e-brake cable through the lca's.
Old Sep 13, 2006 | 12:55 AM
lrgnation's Avatar
lrgnation
Default RE: Removing LCA'S
its kinda an either or situation. if you have a plasma cutter then cut it otherwise just undo the ebrake.
Old Sep 13, 2006 | 01:29 AM
ren274u's Avatar
ren274u
just disconnect it from the caliper
Old Sep 13, 2006 | 12:52 PM
MusiccityGT's Avatar
MusiccityGT
Dude, don't cut it! It is 1 little clip! You can pop the cable off in 10 seconds!
Old Sep 13, 2006 | 01:16 PM
CrazyAl's Avatar
CrazyAl
Musiccity is right, the cable is easily disconnected at the caliper. It is LITERALLY a 10-second job to disconnect the cable.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
