LCA s
Old Oct 11, 2006 | 07:53 AM
Bulitt's Avatar
Bulitt
Default LCA s
Getting ready to buy some lca but cant decide which ones to get i really like the steeda billet set but here they break if u have these let me know how u like them and if u got much more noise compared to the stock set , im also looking at the bmr billet set and the bmr adj. arms also let me know what you all think
Old Oct 11, 2006 | 09:54 AM
CrazyAl's Avatar
CrazyAl
Default RE: LCA s
I would avoid the Billet ones. They are very expensive for a part that is difficult to see. And then there's the history of the Steeda ones breaking.
The tubular steel type is both lighter and stronger than the aluminum ones, and the price is much nicer!
If you have (or are planning on) lowering your car or getting an aftermarket driveshaft, then get the adjustable LCAs. If not, get the solid ones.
Old Oct 11, 2006 | 05:38 PM
scramblr's Avatar
scramblr
Default RE: LCA s
ORIGINAL: CrazyAl
Or you could get the non-adjustable one's if you get an adjustable UCA, no?
Old Oct 11, 2006 | 05:55 PM
CrazyAl's Avatar
CrazyAl
Default RE: LCA s
ORIGINAL: scramblr
ORIGINAL: CrazyAl
Yes, that is a valid option. If you need to make adjustments you need adjustable lowers OR upper.
Personally, I prefer adjustable lowers and a solid upper. The reason is that the lowers are much easier to access for adjustment than the upper. Also, the adjustable lowers are a stronger option than the adjustable upper.
Old Oct 11, 2006 | 06:00 PM
scramblr's Avatar
scramblr
Default RE: LCA s
ORIGINAL: CrazyAl
I already did mine, so this is just a question for knowledge. Good point on the access, although it's not too difficult to get to the UCA if you can get on a lift. But why do you say the adjustable lowers are a stronger option? Thx...
Old Oct 11, 2006 | 06:53 PM
CrazyAl's Avatar
CrazyAl
Default RE: LCA s
ORIGINAL: scramblr
For two reasons.
First off, I have yet to see a UCA that really looks "bulletproof" except for the solid (non-adjustable) ones from BMR. The others, including BMR's adjustable type, are just not as solid. I haven't tested them all to failure, but that is my opinion as a mechanical engineer based on handling many of them.
Second has to do with the distribution of forces on the rear end. An adjustable part is going to be weaker than a solid part as a general rule--there are more opportunities for failure on the adjustable piece becasue of the adjustment mechanism. On the rear end of these cars there is only ONE upper control arm. That single UCA must bear a similar load as BOTH of the lower control arms. The LCAs are much more lightly loaded (individually) than the UCA is. Therefore, I'd rather have my "weak spot" on the LCA rather than the UCA becasue the LCA has a higher "safety margin".
Keep in mind that all this is nitpicking. I have yet to hear about a UCA failure. There's a lot of guys running adjustable uppers on very fast cars. I'm just explaining my preferance for the solid upper and adjustable lowers.
Old Oct 11, 2006 | 07:08 PM
scramblr's Avatar
scramblr
Default RE: LCA s
ORIGINAL: CrazyAl
ORIGINAL: scramblr
For two reasons.
Great...Thanks for sharing the knowledge!!![sm=smiley20.gif]
Old Oct 11, 2006 | 07:25 PM
Andys06GT's Avatar
Andys06GT
Default RE: LCA s
bullit, i had(have) the bmr adjustables, with rod end and polyurethane end. they made a huge difference as far as traction. lowered my e.t in the 1/8th by almosta half second, and gained 3.2 mph. the ride while cruising, didnt really notice the difference. little stiffer, and the rear end didnt hop around as much, but it was essentially the same. however, on bigger bumps, and the pothole i didnt freakin see, you'll know there's something different. its a more pronounced noise that the stock pop that comes when you hit a big bump. but again, it kept the rear in check and didnt pop around as much. if you're looking for some, you can pm me....
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Sep 30, 2015 10:13 AM
FivePointToTheOh
Sep 15, 2015 08:15 AM
JonnyBlazeGT
Aug 9, 2015 10:19 AM
