Wheel offset question...
Old Oct 18, 2006 | 02:07 PM
manichispanic's Avatar
manichispanic
Default Wheel offset question...
I have a question about wheel offset.
I found some rims I like that are size 18 x 8.5 (255/45 tires) with a 45mm offset. Would these fit my stang? These wheels also come in 19 x 8.5 (255/40 tires) with a 35mm offset. If the 18's don't fit, will the 19's fit? Any feedback would be greatly appreciated. Thanks.
Old Oct 18, 2006 | 10:11 PM
Philostang's Avatar
Philostang
Default RE: Wheel offset question...
The 18"s you indicated should fit fine.
Once again:
OEM 17"x8" wheels come with +45mm offset (235/55/17 tires)
OEM 18x8.5" wheels come with +50mm offset (235/50/18 tires)
The difference here is mostly to put the outer wheel face in the same place as the 17" wheel. There's plenty of room for 8.5" wheels with +45mm offset, they'll only be set forward a 1/4" or so from the 18" OEM set up.
Best,
-j
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
