Tire width
Old Apr 20, 2007 | 03:17 PM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Tire width
ORIGINAL: EKB
ORIGINAL: ilduce321
On the Pony Package 17x9 wheels, what's the widest tire than can safely fit on these wheels? I just got an X-Charger, and I'm thinking I want to get some wider tires for the rear end.....
I may be wrong, but I think the pony package wheels are 17x8's.
[/quote]
You beat me to it! TheBullitt wheels for the GT's and Pony Package V6'smeasure 17"x8". You'll have to buy your tires accordingly, or buy aftermarket 17"x9" wheels for wider rubber.
Old Sep 15, 2008 | 11:24 AM
Deadbeat's Avatar
Deadbeat
Is it possible to run 315's out the back? I did on my New Edge, but that was then....
Old Sep 16, 2008 | 09:05 AM
JiminVirginia's Avatar
JiminVirginia
Originally Posted by VSTNG
Probably a stupid question, but is there a reason to not have the same wheel and tire combination on all four wheels? I've looked at some 18x10 Deep Dish Black Bullitts and now I'm wondering if this size up front causes a problem.
I'm using 18x10 FR500s, 40 mm offset, all around, for autocross purposes.
On the front, the fit is marginal, with the 295/30/18 tires coming within 5 mm of the shocks. They clear, but there would be a problem getting a full lock on steering: the tires come up against the wheel wells and suspension hardware.
My suggestion for street use would be to go 18x9 in front, no more than 40 mm offset, and use 275s. They make Bullitts in this size with a 30 mm offset, and I'm sure this would work great with no rubbing issues.
Old Sep 16, 2008 | 05:18 PM
YellowGT06's Avatar
YellowGT06
Here is some help with confusion, on the 17X9 wheel the widest tire is the 265/35/17 for the front. It will allow full turn with no rub, but add a spacer and you can go to 285/30/17. the 285 will rub at the bottom of the fender with a rough road. Rear tire is the 285/xx/17. Any side wall will fit up to a 60, why you would put a 60 on I don't know, but you can. Like I said help with confusion. One of the beat options is to call Discount Tires Direct, you can Google it. The guys there are realy good and can absolutely help with professional advice.
Old Sep 17, 2008 | 11:16 AM
157dB's Avatar
157dB
Cut & Paste Expert
Just a little left over data from when I had 17x8s:
215/65R16 STOCK
8.464" WIDE
27" TALL
84.835 ROUND
747 REVS / MILE
235/55ZR17 STOCK
9.251" WIDE
27.177" TALL
85.379" ROUND
742 REVS / MILE
245/55R17
9.65" WIDE
27.610" TALL
86.739" ROUND
730 REVS / MILE
255/55R17
10.04" WIDE
28.042" TALL
88.096" ROUND
719 REVS / MILE
265/55R17
10.433" WIDE
28.476" TALL
89.459" ROUND
708 REVS / MILE
235/50R17
9.25" WIDE
26.251" TALL
82.469" ROUND
768 REVS / MILE
245/50R17
9.65" WIDE
26.640" TALL
83.692" ROUND
757 REVS / MILE
255/50R17
10.04" WIDE
27.039" TALL
84.945" ROUND
746 REVS / MILE
26" = 81.681" ROUND = 776 REVS / MILE
27" = 84.823" ROUND = 747 REVS / MILE
28" = 87.965" ROUND = 720 REVS / MILE
29" = 91.106" ROUND = 695 REVS / MILE
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
