BMR LCA relocation bracket install questions
Old May 21, 2007 | 11:23 PM
jmsurpri's Avatar
jmsurpri
Default BMR LCA relocation bracket install questions
Hi I just got the brackets in the mail and reading the instructions. It came with 5 washers, where exactly should I use them? Pictures I've seen of the brackets installed don't show any washers anywhere, so I'm assuming I'll use them on all the bolts.
Also there are 5 bolts, 4 the same size and 1 which is about a 1/3rd the size. I don't see any mention of where this smaller bolt is supposed to go.
Also does anyone have any pics of these being installed?
Thanks for any help
Old May 21, 2007 | 11:27 PM
blueherd02gt's Avatar
blueherd02gt
Default RE: BMR LCA relocation bracket install questions
http://www.bmrfabrication.com/INSTALL/CAB005.pdf
No luck with these?
Old May 22, 2007 | 12:24 AM
jmsurpri's Avatar
jmsurpri
Didn't think to check BMR's website.. Those instructions are better than whatI got.Thanks!
Old May 22, 2007 | 12:41 AM
jmsurpri's Avatar
jmsurpri
Hm. I may be wrong but it looks like I should have 6 newbolts total. My kit only came with 5. Looks like I need 2 bolts with spacers for the original mount location, 2 bolts for the control arm, 1 new panhard rod bolt, and 1 bolt for the passenger side top connection. Am I missing something?
Old May 22, 2007 | 12:56 AM
jmsurpri's Avatar
jmsurpri
Can I do the install on ramps or do I need to let the suspension hang?
Old May 22, 2007 | 01:07 AM
drbobvs's Avatar
drbobvs
You can remove the wheel to make it easier to access. The suspension needs to be loaded to re-attach the LCA's so I jacked up the car by the axle.
Old May 23, 2007 | 06:35 AM
BlackBetty's Avatar
BlackBetty
I just reused the stock bolt in the panhard rod and put the new bolts in everywhere else. Not that I can talk since I've got some clunking, but nothing has fallen off.
Urambo Tauro
Sep 7, 2015 12:47 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Mobiusone stang
Aug 24, 2015 04:08 PM
Soldier GT
Aug 12, 2015 03:46 PM
JonnyBlazeGT
Aug 9, 2015 10:19 AM
