front sway bar tightened?
Old Sep 19, 2007 | 09:01 AM
S1ckStang's Avatar
S1ckStang
Default front sway bar tightened?
how do i know if mine needs to be tightened? is it common that it comes loose? and if so can i just climb underneath and tighten it myself or is it hard to get to? thanks for the help.
Old Sep 19, 2007 | 06:52 PM
blackonblack2007's Avatar
blackonblack2007
Default RE: front sway bar tightened?
What symptoms are you having that would cause you to thing that the front sway bar is loose? I have never heard of a sway bar coming loose, unless someone installs one incorrectly and doesn't torque the bolts right. You would need to jack up the front end to get easy access to the sway bar.
Old Sep 19, 2007 | 11:05 PM
S1ckStang's Avatar
S1ckStang
i guess just call it paranoia ir ead one of nonstopreds post about how he needed to have his titghtened so it hought maybe i should check.
Old Sep 20, 2007 | 12:49 AM
blackonblack2007
You can always check the bolts during your next oil change, but unless your handling is significantly different from what it was when you bought your 'stang I wouldn't worry about it.
4cylinderplus2
Oct 9, 2020 07:45 PM
flash_xx
Oct 16, 2015 07:23 AM
Sixer4Life
Oct 12, 2015 04:26 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
