Nitrogen filled Tires?
Old Oct 11, 2007 | 06:52 PM
The Ghost's Avatar
The Ghost
Default RE: Nitrogen filled Tires?
Soooo...how do you get all of that "air" out of your tires before you fill them with nitrogen?
Old Oct 11, 2007 | 07:49 PM
08Steeda's Avatar
08Steeda
Good Question!!! I was wondering that myself!
Old Oct 11, 2007 | 09:31 PM
CityDave's Avatar
CityDave
ORIGINAL: The Ghost
You would need to pull a vacuum just like you do on a A/C system before you recharge it. Only thing is you would not get all of the air out being the tire would not completely collapse and this would leave pockets of old air. Or you could fill the tire with nitrogen then let it out and refill again. What a waste of money for adaily driven car.
Old Oct 11, 2007 | 09:40 PM
Biggdaddy's Avatar
Biggdaddy
I switched to nitrogen 2 months ago and haven't lost a pound of air, my local turner muffler shop only charged me $12 and only took about 20 minutes to do it, so it was well worth it to me.
Old Oct 11, 2007 | 10:23 PM
navyscott's Avatar
navyscott
Pretty much every aircraft tire I've ever dealt with was serviced exclusively with nitrogen. When I've asked why, the answer I always got was the same...
1. Nitrogen is more temperature stable than compressed air (think how cold it gets at 30,000+ feet and how hot the tires get on landing).
2. Fire suppressant in the event of a fire, versus the possibility of compressed air acting as an accelerant.
Not really sure that these two reasons would have much if any applicability to a street driven car.
$.02
Old Oct 12, 2007 | 12:59 AM
Burnsy's Avatar
Burnsy
yeah, i think ill stick with my air compressor in the garage....
Old Oct 12, 2007 | 12:59 PM
shooter23's Avatar
shooter23
I for own a tire garage...and I have read all the reports...and seen the tests that have been done...and I can tell you right now, it is a scam. Yes, it is better for different temperatures...but were talking about temperatues that OUR tires would never see...the fact of the matter about how it doesnt leak...if someone can explain how that would be physically possible, id like to hear it...because no matter how big or small the leak, whatevers in the tire will leak out...the pressure inside the tire is greater than outside thus meaning it will release the nitrogen or air into the atmosphere to equate to equal pressure.
There have been tests compiled comparing the two, and these tests were done on regualr everyday cars and the results, on 3 different cars and tires, showed that paying the extra money (whatever they decide to charge) results in a 1-2% more nitrogen count...and again, that means nothing...because nitrogen is already prevelant in air anyways.
People will believe whatever they want...but in the end, the reality is that one street cars, it makes no difference...and heavy duty use tires, or tires that experiece rapid and dramatic changes in temperatures (aircraft) I may believe it...
Old Oct 13, 2007 | 08:39 PM
08Steeda's Avatar
08Steeda
That is what I suspected. Another gimmick!
Thanks for the info!
Old Oct 22, 2007 | 12:39 PM
Bmr4life's Avatar
Bmr4life
The benefits are negligible at best. 78% nigtogen versus 100% is a wash.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
GLOCKer
Sep 28, 2015 07:36 AM
