new wheels
Old Oct 16, 2007 | 03:57 PM
wadman's Avatar
wadman
Default new wheels
Help I cant decide what size wheels to put on my o5 gt. I am having a Hellion turbo installed next week and because of the way the pipes run they might scrap if I lower the car. I need some traction out back. Im afraid if I go with 18 or 19inch wheels I will have too much gap between the tire and the wheel wells. I know I cant be the only one who has been through this. What are people using that dont lower the car?
Old Oct 16, 2007 | 04:25 PM
22kart22's Avatar
22kart22
Default RE: new wheels
With the 18" and 19" you will have less fender gap, that is, if you purchase the same or larger diameter tire.
Remember, the larger circumfrence tire/rim combo you buy, the less torque you will put to the ground..Well, I used the wrong words...You are screwing with gearing..
I'd stick with either 17" or 18"
Old Oct 16, 2007 | 06:51 PM
UrS4's Avatar
UrS4
Keep the same tire diameter and going to a larger wheel should be fine, you won't change your gearing.
So keep it to 27" and you can put 18, 19, or 20 on.
I would choose an 18 inch wheel as there are some many tires you can choose from and they are generally cheaper depending on how wide of a tire you put on.
With the turbo, you need a 285 wide at least, perferably a 305 but they may require some rear end fine tuning.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
