Eibach Springs... Prokit vs. Sportline
RE: Eibach Springs... Prokit vs. Sportline
The lowering kit will change the angle of the lower control arms, so a lca relocation bracket will return them to the correct angle. Adjustable lower control arms will make installation easier and correct the pinion angle which will be changed by lowering. They alsowill be strongerthan the stock ones. Lowering also pushes the rear axle to the left as the angle of the panhard rod has been changed so an adjustable panhard rod will allow you to recenter the rear axle.
16, comparison, difference, eibach, kit, mustang, pro, prokit, roush, sport, sportline, spring, stock, suspension, wheel
